Sorry, I just tested the free version, so as homestyler.com You should be grateful, you used an obselete browser works under IE 11, Chrome, Firefox, Opera not tested. Possible, I didn't spend 3000GBp, I just tried the free online version. Rather stubborn, but I understand for 3000GBp, you should get the refund. I do not compare with the past, I compare with other archi apps, but I agree, for version comparison, I do prefer Win7 to WinXp. Yes I do want simple 3D user interface such as: homestyler.com wanaplan.com but for different reasons I neither like the interface of sweethome3d nor of Visual Building, maybe in future versions. You may still delete this post and stick to the ostrich policy. |
How can you compare a £3000 product with a £50 product?
I have also tried Autocad 360 and found I had to install another browser just to be able to use, and then I wasted many hours of testing only to lose each project each time my browser crashed due to scripting errors, whatever they are. I found the new Visual Building interface very easy to learn and use (compared to its original interface). OK, so I had a few questions, but all were answered on this forum, and I am a very happy user. If you want a simple user interface, with less tools, and no 3D, then stick with Autocad360, but my vote is for Visual Building!!! |
I thank you for the evaluation.
I forgot to give a feedback, because I initally thought I would further test. Globally, the program appears to satisfy my needs, but its interface is way too complex. Some suggestions: 1/ The select cursor icon should always be visible in the ribbon. Pain in the neck, to have it through the ribbon and not to have always readily. 2/ Most screen are 16:9 in 1920x1080, so the ribbon should be vertical and not horizontal, or a choice 3/ I find changing the compass orientation an hurdle task. it should be a property of the house to have terrain and house orientation (in case several houses on same terrain) 4/ Shadows www.visualbuilding.co.uk/forum/4-visual-...tion-of-the-sun#1189 I do not see, shadow projection onto the ground, soly the shadowed facades Additionnaly, there is no shadows from the 1.5m overhang I created. (by the way, how do you change properties of a selected rood side? In this example, there are 8 roof sides, and I don't know which one is which without trial and error) 5/ About wall and roof construction and editions www.visualbuilding.co.uk/forum/4-visual-...ation-and-moves#1190 5.1/ When you draw/extend walls you don't view the wall's lengths. 5.2 Globally, way to complex, compare with: Just try to create these walls of a kind of U building, L1: 1688 L2: 382 L3: 168 L4: 480 L5: L6: 458 L7: 436 L8: 402 and then add the roofs according to your imagination. Conclusion: The user interface puts me off, too complex, too many menus and/or operations, steep learning curve to do easy tasks. I hope you see this positively and will give a thought about in a next release. |
