Floor Levels 23 Feb 2014 16:53 #1307
This can be achieved in Floor layer dialog, you can define which of the layers is the base layer, which will cause the floor level to adjust.
Floor Levels 23 Feb 2014 16:31 #1305
How do I achieve a floor top level that is at the same level of the level where the walls start to be created from, rather than it being above the level.
E.G – The DP level is set at 150 & has engineering bricks to this course level.
The screed top level is also at 150. See attached basic example.
Could I just use a ceiling on the Basement level as the floor detail ?
MD via email
