Environment Block Shape 24 Apr 2014 12:45 #1415
The environment block can only be rectangular. You can change its thickness and colour.
Use the Terrain tool to create a polyon to define your plot size. ( Terrain - Terrain elements - Bed - Insert with Polygon) The terrain objects normally sit on top of the environment block, and can be textured. You can make the Environment block invisible by placing a glass material on it:
If you want to have a solid block similar to Environment block, then use Extrudes solid tool to create an irregular shaped block. (Applicable to Visual Building Professional/Premium only)
This example has been added to the Visual Building Traing Course Manual .
Environment Block Shape 24 Apr 2014 12:37 #1414
Can the shape of the environment block be configured to resemble the house plot/garden?
Colin D via email
