Concering watching the videos, please see the
Watching Video tutorials
topic
To change the size of the Environment block, ensure the Environment layer is your current layer and then you double click on it, in either the 2D or 3D view (or right click on it and select Properties) to activate its properties dialog where you can then set its size. The Environment block can only be rectangular. You can also draw an iregular plot using the Terrain tools. See also: Environment block shape |
