I have started to create a new version of the project and have got as far as inserting the two dormers. When I then inserted the windows into the two dormers, one appeared normal, but the other was hidden apart from the front of the cill. Both dormers are identical and both windows are identical. This totally baffles me. I shall attach the project file without the windows, so that you can try it yourself. If you wish, I can send it again with windows.
Many thanks, Edward
I'm slowly getting the hang of creating a dormer window and now have a couple of dormers where I want them, which is partly in the roof and partly in the first floor wall. However when I now insert a window it cuts itself a hole through the first floor wall but not through the dormer wall, so in the 3D view I can only see the bottom half of the window. I have done this before and the window appeared without any problems. What may have changed to introduce this problem? Thanks, Edward |
