Wall connections 21 Nov 2014 11:53 #1861
The tutorial has now been updated to advise of the Wall Partition feature.
Wall connections 21 Nov 2014 11:34 #1860
That's helped, thanks.
In that particular tutorial it is suggested that a partition wall is selected, this is misleading if you are advocating the use of a different wall type.
I am now unsure whether to follow the tutorials to the letter or not.
Regards
Ian
Wall connections 20 Nov 2014 19:30 #1852
The project you supplied is below. The bad wall connects are marked red, the good wall connect is green. The exterial wall connects are all good:
As you stated, you have used a Partition wall type, which is a special type of wall. Use a different wall type as you did with the good wall connect. (see User manual 15.1.1 and 4.2.3). The Partition wall type is reserved for the cases where you do NOT want to split a room into two separate rooms.
Wall connections 20 Nov 2014 19:16 #1851
Me again. All things going reasonably well but I am not making good wall connections. I'm going over and over the video tutorial and can't see what I am doing wrong. Whatever I do I don't get the individual room numbers appearing.
I am watching tutorial 2 Part 1 - setting up the project.
I am trying to make the wall connection with the partition wall tool.
Any tips would be gratefully received.
IS via email
