Yes that would work, but remember your trial version would work only for 5 days, although your converted windows can be used without restriction in your Visual Building Basic version.
Visual Building Basic is more than adequate for my project needs and I dont want to upgrade just to do a one time conversion of my Arcom window macros. If I downloaded the trial version of Visual Building Professional, could I convert the windows and then transfer/copy to my Visual Building Basic version?
The Windows Construction tool will allow you to import Arcon window macros that you have created. This is the *.afm file. As this is a simple macro text file you can load this in and recreate your own new windows for visual building.
You could not find this tool in your Basic version because its part of Visual Building Professional (and upwards). You could upgrade from Basic to Professional to obtain this tool. |
I read somewhere that I could use the windows I created in Arcon within Visual Building, but cant see how I can achieve this. Im now using Visual Building Basic, but I used Arcon's window designer to create a set of windows for my project and if possible I do not really want to do these again.
