Re: Your 3D Home Designer Deluxe 2nd Edition Upgrade? 01 May 2012 22:17 #262
You do not need to uninstall Your 3D Home Designer Deluxe, however there is no advantage in keeping it as all your projects will load directly into Visual Building. The projects are 100% compatible moving to Visual Building. There are more features in Visual Building that are not supported in Your 3D Home Designer Deluxe.
Your 3D Home Designer Deluxe 2nd Edition Upgrade? 01 May 2012 21:10 #261
  • Mathew Banks
  • Mathew Banks's Avatar Topic Author
I just purchased your Visual Building Basic version because I wanted to create end elevation views for my projects that I created with 3D Home Designer Deluxe. I thought I was purchasing an upgrade, or do I get a new product?
Do I need to uninstall 3D Home Designer Deluxe before installing Visual Building or will they work together?
if they do work together is there any advantage in keeping 3D Home Designer Deluxe installed?
Are there any known incompatibility issues between 3D Home Designer Deluxe and Visual Building?
MB
