Re: Doors 16 Apr 2013 16:54 #732
This object was imported from the Weathershields Sketchup catalogue entry as a .dae file. converted to a .3ds file and then imported into Visual Building Pro. However the cyg object can be used by all versions.
Download the french doora object: WeathershieldFrenchWindows.cyg and place it in your object folder.
A tutorial showing how to to this for Sketchup objects and 3ds object is here.
See this video to convert an object into a door or window
Re: Doors 16 Apr 2013 12:19 #730
There is a sliding door in the standard door catalogue. Give me the dimensions for the French doors (and description) and I will make one using the Window / Door construction tool (in Premium version). Post note: actually, I found it easier to import an existing 3ds object.
Doors 16 Apr 2013 12:05 #729
  • Andrew Willey
  • Andrew Willey's Avatar Topic Author
Hi, is there an option in the door catalogue to select a double opening French door and a sliding patio door? as I can't seem to find them. Thank you
