Re: 2D Elements 24 Nov 2011 15:30 #81
You can combine separate 2D elements in a contour. At this moment, all elements are converted to a polyline, with filling options etc..
Start and end points of the elements must fit together and of course you can not use a circle, because this contour is closed by itself, needs an arc instead.
A contour can be saved as 2D Symbol or as profile to the catalogs
2D Elements 24 Nov 2011 15:04 #80
I am writing this because I like using nurbs tool like Rhino/Moi 3D and combine with them would be very powerful I mean only 2D sections not the 3D model. As well as when I draw a 2D closed shape by lines and curves I cannot fill it.
[Andras]
