Hide the Feed In Tariff Display 25 Oct 2014 11:38 #1782
There is no FIT disable tool on the Ribbon bar, but if you switch back to the tool version, you can use the View - Info Icon "Generated Power Per Year" menu to hide the display. When you revert back to the Ribbon bar the FIT icon remains hidden.
Ensure that you have a 2D view open.
In Ribbon mode switch to Toolbar using Application menu - Settings - User Interface - Toolbars
In Toolbar switch to Ribbon using Settings - User Interface - Ribbons
You can switch between the different user interface types without the need to restart Visual Building.
Hide the Feed In Tariff Display 25 Oct 2014 11:31 #1781
I would like to hide the Annual Feed-in tariff display. In the older Solar Panel Designer toolbar version there was a menu entry to do this but I cant find this in the new Solar Planning addon that Im using with Visual Building Premium.
