Many of the default windows have a wooden texture applied, however quite often users prefer to have a default white for their windows.
This can be achieved as follows: 1. Select the window in a project 2. Select the 3D functions tab in the ribbon bar 3. Select the Edit Material tool in the Edit Group 4. Click in the frame texture that you wish to change to activate the Material Editor dialog. 5. Right click on the Texture field to activate a context menu from which you should select Remove selection 6. Ensure the RGB values are set to 255,255,255 - the values for white 7. Ensure the Diffuse value is set to 100% 8. Optional step: To make this change for all future uses of this material click on Save as default 9. Click OK and your window frame is now white. |
