Stepped Floor 12 Feb 2014 00:22 #1263
There are tutorials demonstrating how to incorporate a split level, normally the result of an extension having different floor / ceiling heights. However you may just want to raise a section of floor in a building / room that otherwise has same floor ceiling height.
You can achieve this by using the Room Boundary to define a floor section. Then in the new room created with the room boundary activate the Floor properties dialog (right click and select Properties). In the tree locate Floor-General - Layer construction.
In the Edit selected layer section, you can then raise the floor level using the Thickness field.
The floor level will then raise by the value entered.
Time to create page: 0.075 seconds
