Complex Stairs 05 Apr 2014 17:38 #1368
If you need to create a complex stair beyond the ability of the stair wizard...
1. Create the individual flights using the stair wizard.
2. Save the created stair objects as a .cyg object
3. Load the stair objects and assemble as needed.
Alternatively you can save the stair as a .3ds object and load in into the 3D Converter and remove individual elements of the stair, and then save as a .cyg object file.
The following Space saver staircase was created using Visual Building Premium by drawing a P shaped step as a 2D outline (I cheated by tracing an image from the web). I then converted this to a 2D Contour, which I then extruded. I then used the
multi copy too to place 6 copies of the right hand step, and then repeated same for left hand step.
Time to create page: 0.117 seconds
