License 02 Oct 2013 08:59 #945
Please note that Visual Building Lite and Visual Building Basic do not use the serial number / license key system and are distributed as licensed versions.
However the Visual Building Professional, Premium and Solar DO USE the serial number / license key system.
Please follow the license procedure here .
Possible errors:
"The License file was read but contains a license for a different program or module"
Our experience here is that you have requested a license key different to the actual version that generated the serial number.
e.g You installed Visual Building Pro v3 and requested a v4 license.
e.g You install Visual Building Pro 4 and requested a Premium license.
Please double check which version you are using to create the serial number. It is always best to install the latest version from our web site.
