There are many different beam contours / sections in the catalogue. (located in Construction elements - Profiles - Steel Profiles). With Visual Building Professional / Premium you can use the Sweep solids tool to create a beam of desired length useing the beam profiles. Alternatively you can create your own beam profile.
See Sweep solids video that uses this tool to create a drain pipe. Same principle to create a beam of any profile (and a lot easier than a drainpipe) See Visual Building User Manual Chapter 25.8 Sweep Solids |
I need to incorporate a steel frame into part of my model for a future extension - do you have a tutorial or other support material anywhere? I have tried the places obvious to me, but I can't be sure I have looked everywhere..... ;-)
The uprights will need to be standard room height, and the floor support beams will need to span 3.5 metres and 6.6 metres. Thanks, Chris |
