Numeric parallel Guidelines 06 Jul 2017 13:31 #2743
Thanks for williams help on this, however the problem was that I did not have snap to grid on, once enabled the red line appears straight away.
J
Numeric parallel Guidelines 03 Jul 2017 18:08 #2742
  • James Mead
  • James Mead's Avatar Topic Author
Am I doing it wrong or it does not seem to work ?
click on 2d guidelines - guidelines - then numeric parallel guideline, or p as a shortcut, this brings up the select reference line in the bottom left corner, no matter what I do I cannot select the existing guideline.
I need this to be a bale to place a wall easily x distance from an existing wall.
Feedback wise it is very difficult to work with the x y z dimensions otherwise. If the
single dimension tool could show the values whilst placing, it would be advantageous, and make it so much easier, or even be able to extend the dimension with a drag and drop.
Thanks in advance
James
