Cut to plane problem 29 Apr 2020 19:06 #2852
  • Gary Morin
  • Gary Morin's Avatar Topic Author
In this particular case I don't think the objects where side by side. However I solved the problem by copying similar objects from the other side of the building.
thanks
Cut to plane problem 29 Apr 2020 17:25 #2851
problems with boolean operations often appear when the involved solids are positioned edge to edge.
In most cases it is better to let the 3D solids overlap.
- Try to change the size of one of your solids, make one of it bigger to avoid edge to edge situations
- looks as if you would get the same result using "Difference" instead of cutting to plane
If both options don't work we would need your project file. (customercare@visualbuilding.co.uk)
Cut to plane problem 29 Apr 2020 16:30 #2850
  • Gary Morin
I'm using cut to plane to cut some 3d cladding objects to the roof plane. I'm using a rotated cube as the plane but I had the same problem when I just used the roof items. When I try to cut the whole object disappears . I have used it successfully in other for the cladding.
Any suggestions?
Thanks
Time to create page: 0.129 seconds
