Re: Your 3D Home Designer Deluxe 2nd Addition - Plugin 01 Aug 2012 14:12 #335
The Plugins are now included as standard within the following products:
3D Converter Plugin
Visual Building Professional
Visual Building Solar Designer
Plan Layout Plugin
2D DXF/DWG Export Plugin
2D DXF/DWG Import Plugin
Door And Window Construction Plugin
Bill of Quantities Plugin
Solar Planning Plugin
3D Construction Plugin
These were previously sold as individual updates but it is now cheaper to purchase complete products that includes the Plugins that you require.
Re: Your 3D Home Designer Deluxe 2nd Addition - Plugin 17 Apr 2012 09:17 #203
The Plugins are no longer available, as these are now included within various product versions. The Visual Building Solar Designer contains all the features of all the product versions and most of the plugins as standard.
Here is a list of the main features and plugins in each version:
Visual Building Lite
  • Project Wizard
  • Editable Window / Door sizes
  • Roof editor
  • Stair editor
  • Multilayer walls
  • Wall editor
  • Dimension and measurement tools
  • Terrain editor
  • Surface editor (tiled areas)
  • Import bitmap (trace plans)
  • Multiple 2D / 3D views
  • World positioning for shadow calculations
  • Ray tracing
  • Walkthrough panel
  • Create new 2D symbols
  • Timber list report
All the features of Visual Building Lite+:
  • 2D Section views
  • Isometric 2D projection view
  • Enhanced 2D graphic edit tools
  • Export .3ds, .cob
  • Export to Google Sketchup (via .3ds)
  • Item list report
All the features of Visual Building Basic +:
  • Import DXF/DWG (Plugin)
  • Create new Window / Door designs (Plugin)
  • Create new 3D objects (Plugin)
  • [/color]
  • Edit existing 3D object’s materials
  • Create light source objects (lamps)
  • Import 3D objects (.3ds)
  • 3D Section views
  • Presentation Layout (Plugin)
  • Area / Volume reports
  • [/ul]
    All the features of Visual Building Professional +:
    • Export DXF/DWG (Plugin)
    All the features of Visual Building Premium +:
    • Fast project creation
    • Automatic solar panel placement
    • Calculate FIT
    • Solar installation report
    Re: Your 3D Home Designer Deluxe 2nd Addition - Plugin 17 Apr 2012 09:09 #202
    Im using Solar Designer version. Im confused about what plugins are available for this version. Could you please list them.
    Re: Your 3D Home Designer Deluxe 2nd Addition - Plugin 16 Apr 2012 11:35 #197
    The plugins are no longer available as the plugin features are now sold as part of a range of products now sold as Visual Building.
    You can upgrade to each product by simply paying the difference in price between the version you are upgrading from and the version you are upgrading to.
    The RRP of Your 3D Home Designer Deluxe 2nd Addition is £10.20, which we would discount from the price of any Visual Building product.
    The Terrain plugin feature is in all versions of Visual Building.
    The 3D Converter is in the Visual Building Professional upwards.
    Your 3D Home Designer Deluxe 2nd Addition - Plugin 16 Apr 2012 11:32 #196
    Focus Multimedia retails a products called "Your 3D Home Designer Deluxe 2nd Addition", however they do not provide any of the additional plug-ins/add ons.
    Are the plugs-ins such as the Terrain plug-in and 3-D Converter still available?
    [Desmond]
