Re: Hatching 09 Nov 2012 14:48 #482
The UK wall construction layer templates are in the download section of this forum, but they will also be included in the Update available in a few days.
Re: Hatching 09 Nov 2012 14:33 #481
In the above mentioned video tutorial you have some wall construction layouts specifically for the UK brick sizes. where can i download these from?
Re: Hatching 08 Nov 2012 16:14 #479
In all versions of Visual Building you can define alternative hatching in the 2D and even the component parts of a wall. The following shows the steps:
1. Right click on wall for Wall properties dialog.
2. Select Layer construction
3. Click on Default Material
4. Select 2D Display
5. Select Pattern and select hatching style from drop down list.
There is a more detailed explanation of multilayer walls in this tutorial.
2D Elevation views can be created in Visual Building Basic and above.
A tutorial on elevation views can be found here.
There is an explanation of how to prepare and determine your scale here
Hatching 08 Nov 2012 16:02 #477
Hi there I was wondering whether the 2d plans can give a little more detail with hatchings etc bit more like actual architect plans as all the walls seem to be solid and therefore do not give any detail also can 2d elevations of the plan as well as the plan be produced and also what is the best way to ensure i have scaled my drawings correctly or how do i scale my drawings for actual use? thanks
[SS via email]
