I assume you mean that you have created a custom wall layer.
In which case you load the layer using the Open template tool. Note that this is normally a protected folder and you must assign Admin rights to Visual Building to allow you to save to this location. Otherwise load the template from wherever else you saved it. See here concerning Window's UAC and Administration rights. |
