New View Visibility settings / Transfer visibility 12 May 2014 09:19 #1454
The visibility of each component is defined separately for each view, e.g. in the 3D view you can select to show windows, but in the 2D view (or another 3D view) you can select not to show windows. This is a useful feature, but in complex projects where you may have multiple buildings and floors, you may want to see a 3D view of the current 2D view together with all its view settings. Current you need to create a new 3D view and then manually set the view setting to match the 2D view.
So the suggestion is to create a new 3D view that uses the current 2D views visibility settings.
Alternatively have an option to copy visibility setting between views.
