Convert the pdf to a jpg, .bmp and then you can import a .bmp, .jpg, .png or .gif image into your project using the 2D Layout tab- 2D Drawing Functions - Insert Bitmap tool.
Select Insert as Rectangle and from the activated dialog select your 2D image file, and then place the image in your 2D plan. You can then rescale the image. Best place the image on own layer so that its easier to hide/show. |
