change language from German 2 English 07 Dec 2015 12:15 #2371
Which ever language you select, you should be able to change the language at any time using the Application menu (Green top left arrow), then select Settings (Einstellungen), then Language ( Sprache) and then the language. This assumes you selected the new ribbon interface at install time. You will then need to restart the application for the change to take effect.
If you can not manually switch language then the problem is likely to be an incomplete installation, usually as the result of an anti-virus program.
If you are absolutely sure you selected English during the installation then please try reinstalling with any virus checker temporarily disabled. The virus checker may be preventing the language dlls from being installed.
change language from German 2 English 07 Dec 2015 11:54 #2370
  • Richard Martin
  • Richard Martin's Avatar Topic Author
Hi, can you advise how to change the default language, it was clicked to be English but has opened as German
Time to create page: 0.117 seconds
