ceilings are always perpendicular to the floor. If you need a 3D solid that follows your roof pitch you could use an extrude solid from the construction ribbon, best inserted in a section view in which you have the roof as a reference side. You could send your project to customercare@visualbuilding.co.uk, tell us the thickness of the solid and we can prepare an example. Regards Thomas |
I am trying to show a sloping ceiling under a 5 degree slope flat roof extension. If I use the ceiling below I get a flat ceiling rather than a sloped one. I have tried to use the roof boarding material and the interior work material but cannot find a way to get either to display in the 3d view, I can't find a visibility setting for this and although I can change the material I can always see the underside of the roof tiles, green grass in this case.
