Re: Insulation 24 Mar 2013 14:56 #671
Premium and Solar are identical products in all features except Solar has the additional Solar Designer FIT calculations, so unless you are a Solar Panel installer you should select the Premium version. All versions support the cavity wall feature.
You are able to define the cavity wall construction and define the insulation materials used:
Click on image to zoom
Although you can also define the material insulation properties, there are no automatic thermal calculations yet (a future feature):
See also: See the multi-layer wall video tutorial
See also: Multil-layer walls
Insulation 24 Mar 2013 14:44 #670
Hi I am interested in buying either premium or solar but can you tell me if either has an insulation wizard or can insulation be inserted manually. Does either product support cavity walls?
EC via email
