Re: imported 3D object and section line 27 Nov 2011 19:13 #86
Placing the section line in the 2D view creates a new 2D view with a section view. At the moment this is limited to creating a section view of the building components The depth of view of the section is defined by the section box created when placing the section line, but is limited to building components.
With a building you cab create a 3D section using a cuble with a glass material and subtract the cube from the building construction.
imported 3D object and section line 25 Nov 2011 17:17 #84
  • Andras Andras
  • Andras Andras's Avatar Topic Author
My question is how can I cut imported 3D objects (3ds) by section line ? As well as when I move a part of my imported test sphere under the Environment the whole object is still visible on the layout. Is there way to modify the length of the section line ?
