The Export to DWG/DXF feature is only available to Visual Building Premium. The tool is located in the Export menu.:
Make sure that your 2D view is selected before activating the tool: The options will allow you to determine the AutoCAD DWG/DXF format ranging from AutoAD 14 to AutoCAD 2013. You can also determine the scale, and which layers you wish yo output. Using the Tyoes tab you can also switch specific elements to export. |
