Do you mean something like this example, where i added an intricate detail arround the eaves of a building:
Obviously your brick wil be easier. You can achieve this by using the Sweep solid tool or alternatively add a Surface area element to your wall, which you can then texture as brick. You certainly do not want to add a new wall. See also: adding a brick plinth |
I'm trying to add a brick plinth to black weatherboard external finish and am struggling. I've tried added an additional external wall to wrap around set at 10mm thick and 600mm high but this seems to be causing me other weird issues. Any tips would be gladly received. |
