ROOFING ISSUE 17 Mar 2016 11:35 #2494
  • John Cooke
  • John Cooke's Avatar Topic Author
Thank you. I have resolved this issue.
John
ROOFING ISSUE 10 Mar 2016 21:37 #2491
Hi John,
I cannot see any attach projects, would you be able to email it customercare@visualbuilding.co.uk and see if I can resolve this issue for you.
Regards,
Amelia
ROOFING ISSUE 09 Mar 2016 11:58 #2487
  • John Cooke
I am having a problem incorporating a roof in my project. You will see from the attached file that I have created a second floor and using the roof construction polygonal contour tool so that I can add some additional gable ends to the roof I find that the walls are sticking through the roof in a number of places.
To check that my upper floor is correct, I have also used the roof construction on selected contour and the roof is perfect. This makes me think that the walls are sound.
I have tried several time to construct the roof and each time the upper walls show through in a different place. Can anyone advice what I am doing wrong.
Thank you.
John
