There are two different windows types: the standard windows and the window construction types.
In both cases the windows are constructed in the same manner regardless of the material eg wood, aluminium or pvc. You can then drag any material / texture onto a window in the 3D view. When you have the desired material / texture you can use the Transfer Properties tool (right click on the reference source window and then select Transfer properties) This is demonstrated within the following video where a colour / texture is applied to a window frame: |
Hi I am trying to add while pvc windows and white pvc external doors to my project but I cannot find them in the options. Are they in the options? If so please can you guide me. If they are not in the options how can I get white windows and white external doors?
Nick |
