In this example I used the horizontal wood texture located in the following catalogue:
Materials/Wood/Horizontal The example below just drops the texture onto a wall and did not use the surface editor, with which you can get better results. If the web site you quote has any good quality sample images these can be imported in the same way as brick textures . I will ask someone to do an example for this. Applicable to all versions of Visual Building |
Hi
I'd like to try and show the effect of the weatherboard that we'd like to put on our house using the surface editor function. Can you suggest what surface covering is most similar to this product? www.marleyeternit.co.uk/Facades/Weatherb...al-Weatherboard.aspx Thanks |
