Re: Commercial use on flat roof 29 Oct 2011 12:13 #60
A flat roof installation is easy to achieve by drawing a roof onto a flat surface. This can be either on a flat roof or on the ground. Click on the roof and set 3 sides to a gable end and the 4th side is a pitched surface set at the pitch you require. Place your array onto this surface. You can hide the tiles by dropping a glass material onto the tiles.
We will release support for mounting system in a future release.
Flat roof video:
This is a general video for Visual Building, but demonstrates how to create a flat roof
Commercial use on flat roof 29 Oct 2011 12:08 #59
  • jameslamb
  • jameslamb's Avatar Topic Author
Most of the examples are residential on pitch roofs. I tend to specialise in small commercial installations, many on flat roofs. Although I have seen the commercial example images, Im not sure how this was achieved as I cant see any mounting systems. Where are the mounting systems?
Otherwise this is a great tool.
