Robert,
Even in Arcon, the curved walls were not really curves but a series of flat walls. As in a real brick wall, in most cases the curved brick wall consists of many bricks that follow a curved path. It was not deemed necessary to have such a curved wall tool because you can replicate this so easy yourself using the circle or elipse guide line tool. Just place the the curve (or ellipse) where you want the wall to follow and then simply snap the wall to the curved guideline. The more individual wall sections you create the smoother the wall is. This should be suitable for most interior curved walls, and will also work with cavity walls. This solution is applicable to all versions of Visual Building. See also: Curved Walls |
