Re: Change Door hinge and opening direction 03 Apr 2012 10:10 #169
Just right click on the door (or window), and select from the context menu:
Change opening direction
or
Change opening hinge
Applies to all versions of Visual Building
Change Door hinge and opening direction 03 Apr 2012 09:43 #168
I cant find how to change the opening direction of my doors after placing them. If you dont get it right after placement how do you change it, other than deleting it and re inserting it?
The door properties dialog does not have this data. I know its possible because I did it once, but cant find the way.
[SuePuppy]
