there is no auto save function but the software saves a backup file with identical name, ending with *.bak in your project folder. The backup represents the version when your Project was saved the last time. You can load the backup in Visual Building if you rename the *bak file to *.cyp. What you describe could be a problem with your graphic card or the driver. Please install the latest driver version from your graphic card manufacturers web page (and not in your Windows system). And please send your project file and the application log file to customercare@visualbuilding.co.uk for a review. The logfile can be found on your HELP ribbon. regards Thomas |
Is there any auto save feature, as have spent the last hour working, only to have the program crash again !! and revert back to the last saved copy. I have found this program quite buggy especially when using the 3d view, your comments please.
