Re: Wall editing 09 Apr 2012 10:33 #179
The wall editing tools are found in the Edit toolbar. (Hammer and spanner icon) . This Edit toolbar contains 4 edit tools:
Select Wizard, Delete Wizard, View Delete Wizard and the Edit tool. The Edit tool has 3 drop down options: Edit building , Edit 2D Graphics and the Edit Wall. If you select the Edit Wall tool the following options are displayed:
Extend / Shorten Wall
Trim Wall
Change Wall Direction
Split Wall
Edit Fixed Wall Intersection
On selecting each tool the status bar contains instructions for each step of the selected operation.
The edit wall tool is a feature of all versions of Visual Building.
Post note:
New videos add relating to wall editing by stretching floor plan or building:
Wall editing 09 Apr 2012 09:33 #178
  • jasper1492
  • jasper1492's Avatar Topic Author
In Arcon (I had the 3d architect version) you had the ability to edit walls after the walls are placed, but I cant find any similar tools in your Visual Building Lite version. Is this feature only available in more expensive versions? Other than that, I must add that I very impressed with the value for money and the ease of use.
