Custom walls in custom library 25 Oct 2013 06:31 #993
  • julian attwood
  • julian attwood's Avatar Topic Author
Thanks, problem solved
Custom walls in custom library 23 Oct 2013 19:56 #989
I assume you mean that you have created a custom wall layer.
In which case you load the layer using the Open template tool.
Note that this is normally a protected folder and you must assign Admin rights to Visual Building to allow you to save to this location. Otherwise load the template from wherever else you saved it.
See here concerning Window's UAC and Administration rights.
Custom walls in custom library 23 Oct 2013 19:08 #988
  • julian attwood
I've created a custom wall and saved this to a custom library. How do I select this custom wall to use within a plan?
I've tried to select the wall from the library but no luck
