Re: PDF Converter 26 Jul 2012 11:53 #332
If the PDF Converter trial license prompt still refuses to go away after selecting it for delete, then please delete the following files:
PdfConverter.resources.dll in Program Files\Visual Building\Program\Plugins\en-GB
Pdfconverter.dll in Program Files\Visual Building\Program\Plugins
PDF2DXF.exe in Program Files\Visual Building\Program\Plugins\arconos
Re: PDF Converter 09 May 2012 16:15 #275
The trial pdf converter was a 3rd party plugin product and was badly named because it was a pdf importer, not exporter, which one would expect.
If you need to import plans then it is just as easy to import them as a bmp, png or jpg and no need to import as a pdf.
See this topic for downloading a pdf export tool.
So this is not the PDF writer that you think it is. Best to remove it to stop it nagging you:
The total list of Plugins and availability are as follows:
Visual Building Lite
Project Wizard
Editable Window / Door sizes
Roof editor
Stair editor
Multilayer walls
Wall editor
Dimension and measurement tools
Terrain editor
Surface editor (tiled areas)
Import bitmap (trace plans)
Multiple 2D / 3D views
World positioning for shadow calculations
Ray tracing
Walkthrough panel
Create new 2D symbols
Timber list report
All the features of Visual Building Lite+:
2D Section views
Isometric 2D projection view
Enhanced 2D graphic edit tools
Export .3ds, .cob
Export to Google Sketchup (via .3ds)
Item list report
Visual Building Professional
All the features of Visual Building Basic +:
Import DXF/DWG (Plugin)
Window Construction (Plugin)
Create new 3D objects via 3D Converter (Plugin)
Edit existing 3D object’s materials
Create light source objects (lamps)
Import 3D objects (.3ds)
3D Section views
Presentation Layout (Plugin)
Area / Volume reports
All the features of Visual Building Professional +:
Export DXF/DWG (Plugin)
Visual Building Solar Designer
All the features of Visual Building Premium +:
Fast project creation
Automatic solar panel placement
Calculate FIT
Solar installation report
PDF Converter 09 May 2012 16:08 #274
My email was concerning a Popup that I get when opening Visual Building Solar Designer telling me that PDF Converter PlugIn trial has expired, I was not aware that this was only a trial I assumed that as I purchased the top level of product from your company that this would be included.
As I would like to save and print using the PDF feature I would be grateful if you could point me in the right direction to purchase, if necessary, the licence for this PlugIn as I am unable to find it on your website or within the Forum.
[Brian]
