Wall connection 08 Aug 2015 11:16 #2300
Another method or "trick" is to put the walls on different layers, in which case the wall will not connect in the normal way:
Use the Room boundary wall type to define the wall in order to achieve the room integrity.
Wall connection 08 Aug 2015 10:52 #2299
  • Jamie Cox
  • Jamie Cox's Avatar Topic Author
I have found a post that looks like what i am trying to achive but I can't get it to work in the way i think the tool works.
www.visualbuilding.co.uk/forum/5-visual-...ernal-thickness#1551
Is there a video or more detail on how do use the split wall tool
Kind Regards
Jamie
Wall connection 07 Aug 2015 10:40 #2295
  • Jamie Cox
Hi all
I am trying to get the two walls to connect by butting to each other. One of the walls is standard Brick the other is timber frame but what ever i do i cont get the to butt to each other they always join
Is there a trick to getting the walls to butt up.
Thanks
Jamie
Time to create page: 0.160 seconds
