When you deinstall, the project files will remain intact. However I suggest you first copy the Project folder
C:\Users\Les\Documents\Visual Building Basic\Projects (or similar depending on your Windows version / install options) to the desktop and after installing again copy it back. This is just in case you choose different installation options than before. WARNING: The above path is the default path used when saving your projects. You can of course save the project in any path, in which case you should locate the project in any alternate path you used. See Also: Where are my projects See Also: Create multiple backups |
I have been using the trial version of Visual Building Basic and have just purchased the licensed version. The instructions tell me to deinstall the trial version, but I would like to keep the projects that I created with the trial version. Will I lose these if I deinstall?
MW via email |
